Airborn 1.2
edited September 2012 in Airborn Posts: 13
I'm still using Airborn Theme version 1.2. I haven't updated to 1.2.6 because I made so many "tweaks" to the theme's code, that I'm scared if I do an update, lots of things will break.
Looking at the release notes there seems to be only small changes between 1.2 and 1.2.6 - I'm just wondering if there were any security holes patched, or other things that I should be wary of? Am I safe to stick with 1.2?
Best Regards, Chris!
    Hello there.
    It have been hell of time since I have made anything to Airborn so I don't quite remember:-) If you don't experience any problems you can stick with your version. Also you should not update WP (3.2.x fits best i think) cause theme might not work good with newer versions of WP and Airborn is no longer supported.
