Suddenly one of my navigation menu links no longer works. When I click the 'contact' link, nothing happens and there's some code appearing in the url:
http://gloriaconfiture.com/#a13_nava_id_340. The other links are fine. Any idea about what could cause this problem?
Tnx,
David
I think that's what happened:
while editing home page You've changed the 'Navigation anchor' parameter of the row containig entire 'Contact' content block.
I've looked into page code, and this 'Conctac' content block has id attribute set to 'a13_nava_id_460' - so problably You've added Navigation anchor here http://gloriaconfiture.com//wp-admin/edit.php?post_type=nava and while editing Home Page You've pointed this new Navigation anchor as 'Navigation anchor' parameter of row containing Contact. (see scr.png)
All You need to do is to update Navigation Menu.
Both our "Home" and "Group" links don't do anything anymore.
We did not make any changes to the home page at the time. Have also checked the Navigation anchor parameter of the row containing the block as suggested above. It all appears as it should be…
Any thoughts as to what could be the problem?
Thnaks
Mandy
wesbite link: http://goo.gl/9vUbAC
the problem is already fixed and we'll release the update very soon, day or two.
