HI!
I need a link of the footer or the web. I´m from Spain and need a "Terms of use" in every single page, so I need a link on the footer.
The html code is ok, but it doesn´t work! Can you help me, please?
I attach two files for your information^^
Thank you VERY MUCH
http://www.bluebirdcomunicacion.com
The web is in maintenance mode
do you need user/pw?
send it via private message
what browser You're using? which version? what device? what OS?
you must hate me. I´m sorry, It´s not working on my computer.
Using chrome 47.0.2526.80 (64-bit)
imac OS mavericks
But if you say everything is ok, I have nothing left to say about sorry
I rated your theme with five stars!
is not working on the laptop either and the cellphone
what am I doing wrong?
Thank You for this report.
This will be fixed in upcoming update.
quick fix for now:
Please navigate to Xpert Options >> Custom Style and paste this definition:
yes
i´m afraid is not working
good news
go go go!
Have you been doing something?
magic!!
amazing support
