Hi!
I’ve been using your theme for a while now, and found it pretty easy to use. So thanks!
Just having one problem with video embedding for my portfolio. When I insert a video from video, I get these black stripes on the right and left. Any idea how I can avoid that?
Here is the site:
http://imi-productions.fr/ [Portfolio ‘Garmin’ for example’]
Thank you very much!
Quentin
the video has width set to certain value (it's 100% of parent container) - so You can change it's width manually (but it'll affect all works sliders) or change it's height:
1. first option: go to Chillout Options >> Custom Style and paste this definition: 2. second option: please go to Chillout Options >> Works (portfolio) and set 'Slider height' to something like 610
according to my test it should do.
Thank you very much for your help!
Option 1 works perfectly apparently
thanks again,
Bye
