blog entry problems
in Xpert Posts: 11
Hi!
I hope your holidays were well!
I have a problem with facebook comments plugin. If you link the blog entry with the exact URL, it works. BUT, if you read the blog through the normal navigation, it doesn´t appear.
Is there any option to show the blog post without anchors?
Maybe the next images make it clear.
Thank you sooo much.
