Hi!
When creating an album as a grid, when clicking on an image, lightgallery plugin is lauched (popup).
Is it possible to load the normal slider instead of the lightgallery?
If not is it possible to display the lightgallery under the menu (it's now taking the full screen with an absolute position, hiding the menu).
Cheers
Only thing I could think of is to try to move it down with custom CSS:
.lg-backdrop, .lg-outer {
top: 150px;
It's a pity. Do you think you can allow to have the normal slider in the future? Or is it too complicated to implement?
Cheers
