full width row and no spaced columns
Hello. I want to create a full width row with 3 columns without any space between them.. but i cannot find where is the full width setting and where config the column spacing... i tried and i had A.jpg but i want B.jpg.
Angelo
    If You have a row divided into 3 columns - please check to top part of the column, You should have a 'pencil' icon, click it - this will open an edit panel of this column, where You can find 'Design Options' tab.
