Hello, it's rather difficult to predict what is actually happening within your installation. If You can provide me a login credentials do admin panel - please do so, I'll take a closer look at it. Do it please only via private message.
As long as numerous of features of Adamant theme are based on Visual Composer it is not a good idea to remove it.
Hi. 1. You're using Adamant ver. 1.4.3, but the latest one is ver. 1.5.4 - I highly recommend to perform and update. 2. The general rule is to deactivate all extra plugins (not shipped with theme itself) that are installed by website administrator, and then check if something is going wrong with the theme. And You have a lot of extra plugin installed.
URGENT: Website is down please help. Tried to upgrade the visual composer and website broke down
Hi there
My website is down after upgrading my visual composer (please help)
www.virtualwalkthrough.com
Fatal error: Call to undefined function vc_set_shortcodes_templates_dir() in /home/content/p3pnexwpnas06_data03/54/2410954/html/wp-content/plugins/vc_extend_apollo13/vc_extend.php on line 15
Hi there
If the site is down You need to upload the plugin manually, please refer to: https://codex.wordpress.org/Managing_Plugins, 'Manual Plugin Installation' paragraph.
