Remove Breadcrumb and Whitespace
1. How can I remove the woocommerce breadcrumbs from product pages?
2. After the woocommerce breadcrumb is removed, how do I get rid of the whitespace and move the product title up? I need the product title to be at the same level as the top of the product image.
Thank you!
    I think fastest way would be to use custom CSS:
    .single-product.woocommerce .woocommerce-breadcrumb{
    display: none; /* hide breadcrumbs */
    Second won't be so perfect, as it is top of container, which is not visible in your case. However you can try this custom CSS:
    .woocommerce div.product .product_title{
    margin-top: 0px;
    .single-product .content-column{
    padding-top: 0px;
  • Worked great. Take a look!
    849 x 618 - 434K
    Very nice :-)
    Have a good day
