Good Day
I have added a few images in the shop. All my images are Landscape. As you know all your demo shop images are portrait to look nice on mobile. How would you recommend setting up landscape images for presentation ?
You can see here
http://www.alcaidesa.photographyIf any other photon owners have solved the problem i would be grateful if you could share.
Many thanks Simon
First of all you must change the thumbs size. You can do it here: https://nimbus.everhelper.me/client/notes/share/382932/8urxDd21qfAI21cqGubTVhwrQnbwkdML/
You can change to more vertical resolution eg.
1) Catalog Images: 320x280px
2) Single Product Image: 590x500px
Second thing that you must do is to rebuild the thumbnails using the "AJAX Thumbnail Rebuild" plugin.
I hope it helps
With Regards
You can change to more ""vertical"" resolution eg.
Kindly Simon
With Regards
Apologies for gate-crashing your exchange but I have a similar question.
Once I set up my shop, I would like to have both Portrait and Landscape formats. Is there an option to set the resolution as described but for both?
Kind regards,
Alistair
