When viewing the website from our iphone (5s - version 8.1 - using Safari) my images - especially background images - are not responsive. What can I do to fix this?
And You would want those background images to shrink? As far as I know - the behavior of those images are ok. Both of them have size set by this rule: background-size: cover; which means that whatever the size of this content block is the background image will: 1. not be deformed 2. will cover entire content block.
can You point which area has problematic background image?
which means that whatever the size of this content block is the background image will:1. not be deformed
