Hello, this is a pretty important issue and I don't think it should be considered a "custom" issue as the chillout theme allows you to make changes on the backend per typography settings (see screen shot 1), but when you make the changes they aren't reflecting on the front end of the site.
Please refer to my screen shots.
I would like all headers h1, h2, h3. h4, h5, h5, h7, h8, etc. to have the color
#455560.
All body font should be the same color. Please refer to the screen shots for the headings that aren't being changed to the correct color. Where and how can I fix this, please?
If You want to change the color of this element then address changes to this css selector:
.g-link .cov span strong
go to Chillout Options >> Custom Style and paste this definition:
I added some css definitions into Custom Style.
