text block on visual composer
Hi, in every text block i use, when i publish the page or post i have a strange result: the first paragraph is showed differently from the rest of the text.... you can see what i mean watching to the 2 attached image...the backend configuration on visual composer and the resulting frontend...you can see the bold effect i have... can you help me?
Thank you very much
    Hello!
    Please go to Adamant Options >> Layout >> Typography and find 'Font settings for first paragraph of content block'
    You can set different styling for first paragraph. Just make those setting identical with 'Font settings for content'
  • great it worked. thanks!
