Mobile Menu Padding
When viewing website on mobile device the menu/ logo padding covers the top part of the site. How can I take away the padding mobile version. I've set up the padding to 0 on the customizer section, but that did not do anything. Also can I just remove the Logo completely? I'm ok with just having the navigation be the 3 lines on top of the screen.
thanks!
    There are special settings for padding of logo on mobile, see screen shot:
    If this still wont help then please send link to your site, and I will check what can be done.
    275 x 519 - 19K
  • Yeah I have this set to 0px and still happening grimhearts1985.com
    I think I know what is going on. You have different logo for normal screens and High DPI screens. It should be same proportion logo, just higher resolution, so it will behave properly.
    http://apollo13.eu/docs/thirteen/#!/customize_logo
  • Great this solved it!
    thanks
