last theme version problem on bottom menu bar
we installed the new last theme version and, as you can see from the attached image, the menu bar is not fullwidth.
Can you check it please? www.progettocologno.it
Angelo
    Hello!
    This is a glitch, we'll release a bug fix soon.
    For now: go to Adamant Options >> Custom style and paste these two definitions:
    .full-width-elements .a13_row_container.a13_full-row, .full-width-elements .a13_full-content .vc_row-fluid {
      max-width: none !important;
    .wpb_column.vc_column_container.vc_col-sm-12 {
      padding-left: 0!important;
      padding-right: 0!important;
    said: www.progettocologno.it
