When I want to work on my website, in for example 'my messages' or my work and choose an article the article opens up. But when I want to add for example an link by clicking on the icon in the 'bar' my wordpress does not react and I cant scroll anymore.
Can you help me with this.
My website is www.lawrenceubachs.nl
I'm sorry, but I think I'm not quite following You. what do You mean by that? Are You talking about administration area? Is it happening during editing Home Page, or maybe some post?
You can send a screenshot to show me more.
What I mean is when I want to work on my website, I want to write a post or adjust an existing on.
I did not try if I have the same problems with working on the homepage.
The problem is that if I want to add a new post or work on a existing one, nothing works except the normal writing.
For example if I want to upload a photo it does not work, or if I want to add an external link the pop-up window does not show up and the pages freezes.
See the printscreen!
on the screenshot You have hovered mouse over 'Remove link' icon. Are You aware of it?
the main question: do You want to compose the post just like You compose Home Page? Means with Visual Composer? if so: go to Visual Composer >> Role Manager and find 'Post types' control, set it to Custom and check 'posts' and whatever You want more. Then You'll be able to design posts with Visual Composer.
If not: please send me login credentials to admin panel, do it ONLY via private message. I'll take a look at your website from inside.
I will send you my login credentials so you can see what I mean.
Cheers,
