Hello, i have put a new series of pictures on my website with albums functions, with a size of picture 1000*667.
With the slider, my pictures are more tall that my original size. (
http://lucaskozak.com/album/bright-falls/)
And i have tested with all choices of fit images, nothing give a original size.
How do ? Thank you very much!
What about option Fit when needed - it is best for small images, that shouldn't be stretched to bigger sizes, only to smaller(to keep them visible)?
http://lucaskozak.com/album/les-etes-imaginaires/
Thanks for this report. I was able to fix it.
Please go to thirteen\js\a13-slider.js line ~1284
and change this: to: With kind regards.
And for the pictures in portrait ?
