hi, thanks for this amazing theme ,
I have a website with 2 language ( RTL , LTR ) arabic and english
when I create the arabic pages with WPML plugin , the menu appearing in the right way after the latest updates , but still the page damaged !!
please check my website here :
http://bloozar.com/
What you mean by damaged? It looks like your content is empty on Arabic version. Have you filled content in these translated pages?
Btw. Your page points to files on your localhost
http://127.0.0.1/trust/wp-content/uploads/2015/12/logowhite.png
and you should probably fix this :-)With kind regards.
thanks for your quick reply,
my friend I have the same content in english , see how is the background look like ,, !! everything is floating to the left
I think you experience same issues as other users when they try do RTL with visual composer
See this topic
http://support.apollo13.eu/discussion/3662/starting-building-a-site-by-modifying-the-rtl-demo#latest
It looks that visual composer author still didn't fix it.
If you will use standard content without Visual composer it will work fine.
So we wait:-)
When I switch to Hebrew version of the site there is some strange behavior wit row image elements. The images alignment is shiftы to left side of the page.
I tried to maintenance it with various of settings including your suggestion of putting this CSS in the VC: But in than images cuts and aligned to the right side.
Can you see it? Maybe you have some experience how to fix it. The page i'm writing about is http://test.levslutsky.com/he/the-photographer-lev-slutsky/
The same issue occurs in this page
http://test.levslutsky.com/he/צרו-קשר-עם-לב-סלוצקי/
By the way - do you know if there is a possibility to define "contact info" widget to be different layout in RTL languages? If I put a phone number in the widget that on the sidebar the Hebrew version will be flipped. Now it looks "ok" but it's not if I want to edit numbers.
http://test.levslutsky.com/אודות-צלם-אירועים-לב-סלוצקי/
Visual Composer is counting where is header and try to center according to these calculation. They can get messed when resize events are fired. Can you show me what you mean when it doesn't look as you wish?
As well I attach screenshots to illustrate the problem with RTL inContacn form widget text. It looks like can't be written independently in each language so in Hebrew(think in Arabic as well) it's appears flipped.
I see you have used hyphens to get around this:-)
However you try such custom CSS for this one: About alignment:
I don't think I can do anything about it, as this is pure issue with Visual composer, and as was said in this topic Visual Composer is still not RTL ready. It is nice we could make it work proper with such nice CSS trick.
Anyway alignment looks good after page reload, and this is most important.
In your case I would be more concerned about putting white text, on photos with white places in background.
To be honest i have big difficulties to read these texts with out struggling. I would add there some background or overlay on these photos on your place.
Even if you position this text on your screen you can't be sure that it will have same position on other resolutions.
Your solution:
"However you try such custom CSS for this one:
body.rtl .widget_contact_info .phone {
direction: ltr;
text-align: right;
works just fine. Thank you!
By the way, maybe it can be fixed same/some way the alignment of icons in menu & menu widgets?
When the menu change it's position to right -in Hebrew version- icons o not flips & native language reader feels discomfort look on it.
I attach to screenshots to illustrate it.
I can only think of one CSS solution - that is to try to flip it with CSS 3D transformation, but it sounds like too much hassle for such small things, and it may look distorted.
