Thanks for your support. I include the CSS style but there is a problem. The area is bigger but the text is hidden like before. Is any way to show the text area on mobile??
I have another question, if I have to open a new discussion, tell me please... I configured all to show all parts of an image when I hide the menus on desktop, but when you do it on mobile, the image cuts on the menu when you hide it, the image don´t get bigger... i hope you understand me... sorry for my english..
This is background image so it wont be so easy. Its current click area size is 22x20px.
You can try such custom CSS to increase click area: With kind regards.
Best regards.
Ok, I know, sorry about that.
http://www.pilardiazediciones.es/
If you want to make text visible again, then remove code I gave you previously, and add this instead: Should do it :-)
As for your second question I don't understand it fully. It will be good if you start new topic and show me on screen shot what you mean.
Thanks again, great job and support!!
Best regards.
