Good Morning! I’m sure in three stages:
1 ) How do I translate the blog text ” read more ” ? Which file?
2 ) How do I translate the text of comments ” Leave a Reply” ?
3) file which can translate the texts from the main menu? “Resume , profile , contact”
the domain is www.edsoncaldasjr.com.br
comments.php file
refer to: http://www.apollo13.eu/docs/xpert/#!/configure_page
just change the 'Tile title'
If You want to translate it in more recommended way - please refer to: http://www.apollo13.eu/docs/xpert/#!/translating_theme
The item "three" was not possible to edit the menu text .
Can you please explain in what file do the translation of the "Load More" button?
please edit home page and refer to: http://www.apollo13.eu/docs/xpert/#!/configure_page step by step
If You display a posts list - You're doing it with use of 'Post Grid' shortcode, aren't You?
And this button 'Load more' is displayed by this shortcode.
Edit this shortcode (while editing Home page) go to 'Load More Button' tab and change the text.
