Visual Composer is not working, either front end or backend. I know there might have been some issues with the WP 4.5 update, so what do I need to do to get it working again?
Hello, the Adamant theme has been updated and it has now latest version of Visual Composer in it. Please download the latest version from Theme Forest. If You did it, and You still are facing problems - please provide an url to your website.
Hi, I had the same problem but fixed it. 1) Totally delete all all files in js_composer 2) upload new I think that problem in my case was that server saved some old files
Yes, the Visual Composer plugin has some flaws that prevent it from being updated automatically. You need to update the Visual Composer plugin manually.
Are those the correct versions? It's still not working.
Here's the site: http://inspirationsdancecompany.com
2) upload new
