I was wondering if there was a way to change my blog posts presentation to make them appear with a full header such as this page goo.gl/gogiiI
If not do you know any plugin that could do the job
I would like to have a different image for every post and use layerslider to animate texts
Thanks for your help
You can try to achieve something like this with Visual Composer plugin(you have installed probably) and make row full height with adding backgorund - it should give similar effect. However you will have to try it on your own.
Thanks.
I tried to change the columns position settings to "stretch" but it won't work (come back to "middle" each time)
Are all VC functionalities enabled with this theme ? I would like to ask VC support but they ask for a license which I don't have since it was included in the Blame theme.
Could you please provide a link to help me. I am a newbie and I feel completely lost.
thanks
If you want to enable all features of ROW in Visual Composer(and lose some of theme interference in it) please do such change:
Go to file blame\advance\plugins\js_composer_mod\config.php
Remove code from lines 86-360
It begins with: and ends with: Then you will have options to set row to full height.
Hope this helps.
