Hi there.
Used Poedit successfully to translate ALL strings to Portuguese (Portugal).
But the following strings are missing in the .po file, so I can't fully translate the frontend:
1— "Recommend this" in "like" icons (mouse hover tooltip).
2— "Click and enter your password to view content" in Albums List (homepage) when content is password protected.
3— "password" inside the form field on a password protected page.
4— "SUBMIT" button on a password protected page.
What should I do to translate this 4 items?
Thanks.
Best regards,
Carlos
1 - Is from plugin "I Recommend this", so you have to check how they do it.
2,3,4 - I see they are missing in translation file, let me fix it.
In attachemnt you have 3 files:
default.po and default.mo upload to \thirteen\languages
posts.php upload to thirteen\advance\utilities
Thanks for reporting this.
