Post grid item info formatting
in Fame Posts: 9
Dear Sirs,
Thank you for great theme and support!
One question - please help - need less info at each post grid's items - only thumbnail and name needed (information that should be hidden is marked with green colored line). Is it possible?
    From what I know you can create your own grid item in Visual Composer -> Grid Builder, and then use it in "Post Grid Settings" in tab "Item design". This way you can remove what you don't need.
    See for example
