Change "text opener" conditions for appearing
in Photon Posts: 8
Hello, I would like to change the conditions (I mean pixel resolution) when the "text opener" appears . I want it to set to appear just on really small screens, because mainly I want to show the text.
    Try using such custom CSS:
    @media only screen and (max-width: 768px) {
    .slide-caption h2.title,
    .slide-caption .description{
    display: block;
    .texts-opener{
    display: none;
  • edited June 2016 Posts: 8
    This works perfect, thank you. But how to avoid overlaping text with symbols? On bigger screen the sentence is broken after some words.
    322 x 483 - 278K
    984 x 686 - 909K
    Post edited by Sani on
    You can try to add such custom CSS for this:
    .slide-caption {
    max-width: 45%;
    works
