Map issues and contact page questions
Hi
Look bellow at my attached pictures what happens with the google maps background on contact page.
First of all, a little bit of maps is loaded and displayed correctly for maximum 1 second then i get error with "OOPS"
you can check it out on www.antimetil.ro/contact
Another question, how can i edit the contact form?
first the map is loaded .. sort of
then fails
Please help me! :D
    Hello there:-)
    Contact form can be edited in: beach_apollo\advance\utilities.php line around 422 function a13_contact_form
    For map it looks like google needs now API key for this map to work for every client
    So first go to https://developers.google.com/maps/documentation/javascript/get-api-key and click "Get a Key"
    When you will generate key for browser you have to add it like this:
    Go edit beach_apollo\contact.php line ~41
    and change <script type="text/javascript" src="https://maps.googleapis.com/maps/api/js?sensor=false"></script>
    to <script type="text/javascript" src="https://maps.googleapis.com/maps/api/js?key=YOUR_API_KEY"></script>
    Change YOUR_API_KEY to your key.
    It worked for me.
