.text()
.html()
<br />
<p>
It is not possible right now, cause we have use
.text()method of jQuery instead of.html(). I will later post here tweaked script, but please tell me do you use compressed version of scripts or normal? I mean this setting http://apollo13.eu/docs/spaceship/#!/advance_menu_use_compressed_js_amp_cssWith regards.
I haven't changed any setting - so would be using the default option which is compressed CSS I believe.
Now you can add
<br />and<p>tags to format code in description.Let me know if everything works ok:-)
the attached file is also good for version 1.3
EDIT by Air:
It was by made for 1.3
