A few problems!
Hello there,
I bought a new style, but I'm having a few problems.
I'm doing the installation according to the installation instructions. But I also install plug-ins and VUSIAL COMPOSER SLIDER REVOLOTIO because it fails to be licensed.
these add-ons from within the theme, why not licensed?
How should I solve it?
    we have a license for those plugins, and you are permitted to use them as an integral part of our product.
    Are you facing problem with using those plugins?
    I threw Chillout theme folder to the folder. I have active admin panel also gave warning to the installation of add-ons.
    Installed all; He gave no warning of the license.
