Hi there,
I would like to get rid of all the page titles on my site. Can you tell me by any chance how to remove them? I selected "Disable" option in Customize>Page settings>Single Page-title bar, but the title still appears in all pages aside from Home screen.
website: www.masha.gallery/
Thanks,
M
If you disable it globally then it can be one of two things:
1. Check in each site if you Title bar-> Title bar look set to Global settings
2. You can have cache plugin that could block this switch.
If non of this is true then I can take a look.
I checked (1), and have turned off all titles per page. I have even tried to delete the Page title in page.php, and this gets rid of the Page title great, but unfortunately, this still leaves the big blank space at the top. Ideally, I would like to have no Page title and no blank space.
I also know it's not (2) because I installed the demo and started the site over with no plugins and no content.
I'll send you a temp admin access via Message.
Cheers,
M
I have checked your installation and couldn't resolve this issue yet.
I see you have lot of plugins, some probably from other themes. You also had Redux Plugin from other theme, and this why our slightly modified version of it didn't install(we have to solve such situation on our side). However I have now installed our version, so we are clear here :-)
I see you have one drop-in plugin object-cache.php APC Object Cache. This is plugin that can not be deactivated from admin panel, only removed by FTP. Please try and remove it for now(make copy of it) and see if it will help for this issue.
To do it, log in to your FTP and remove file object-cache.php from wp-content/plugins/
Let me know what other plugins may be conflicting. I am happy to delete them altogether.
M
About plugins - you have to decide what you use and what you don't cause each plugin that is activated slows down your page on admin side and on client side.
Do you have any other solutions?
http://www.dgtlmrkting.com/dgtlmrkting/
Fantastic theme otherwise
Manny
Have you tried deactivating title bar in your home page exactly?
About your second issue - please start new topic with screen shot showing which one you mean. Thanks.
Yes it's deactivated.
When I look at it in visual composer this is what I get.
Thats done it, I'm not building an eCommerce site so fixed for me.
Thank you
1. There is now a blank white ribbon where the title used to be on the About page (it appears both on desktop and mobile) - I did not find an option to fix this. http://masha.gallery/about/ (image attached)
2. The Contact page now appears to have no blank columns on left and right on my mobile phone (I have it set in the Visual Composer as three columns, with all the content in the middle column), though it looks great on desktop. If I don't have the columns show up on a mobile device, the content looks really awkward. How can I fix this? http://masha.gallery/contact/ (look on your phone; image attached)
I'm happy to post this in a different thread... but I think this is related to what you did to fix the Page Title issue.
M
1. Change option Content top/bottom padding while editing page.
2. This issue is rather not connected to title. I think you should add some padding for this column so it will have space. You know what - please start new topic for this one and I will ask Daniel to help you with is as he know Visual Composer inside out :-)
Thanks again,
Mariya
Cheers,
Mariya
