Mobile friendly-dropout
in FatMoon Posts: 8
Hi
Ive just had a look at the site on my Ipad and part of it doesn't convert well to mobile.
What can I do ? http://www.dgtlmrkting.com/dgtlmrkting/
Manny
    Hello Manny
    Please check these settings in your visual composer: http://nimb.ws/5fJVhv
    Each column must have the settings that are in green boxes.
    I hope it helps :)
    If it not working or you are not able to locate, please send me temporary access to your wordpress admin panel via private message (Remember. Do not paste the password here!)
    With Regards
    Lead Graphic Designer
    Hi Daniel
    Perfect, thank you so much.
    Manny
    Thats great Manny! :)
    Dont forget to rate our theme if you like it. It will help us a lot ;)
    With Regards
    Hey Guys
    I'm having movement issues on Ipad's, there is to much movement. I've tried with theme settings and the Visual composer and page settings. http://www.dgtlmrkting.com/dgtlmrkting/
    Manny
    Hello there:-)
    Could you describe it in more details?
    Is this new question is related to this topic? If not please start new one, thanks.
