Brick Margin Bug - Albums list appearance
in Photon Posts: 6
Hi!
Im from Germany, so sorry for my English. I will show you some Screenshots.
I can easily change the Brick Margin and everything look quite fine..until i close the "Customizing" area and see the page without it. Everything over 2px Brick Margin brings the whole album list to the right as you can see on the second screenshot.
I also can not change the background Photo as you see on Screenshot 3 and 4.
And yes, i saved all the changes i did.
Thank you in forward for your help.
    Hey, i fixed that bug. I had to log out to see and have the changes as i want them. But now...i have the next bug... i can't remove or change that background Image from my album list. It just there. As always the background image can be removed or changed in the "Customizing" area. But after leaving the "Customizing" area ...nothing really happen.
    Even if i log out nothing happen.
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    Hi there:-)
    It sound like you are having some cache plugin installed - do you? You shouldn't activate such plugins until you are done with changes in layout of your site. Otherwise you will have exactly same issues as you described.
