Hi guys,
I'm having a problem with the tabs in my site that is using your Chillout theme. The page is
http://nextlevelescape.comUnder the 'Our Rooms' section the tabs won't display properly – only the first tab displays, the other two will not turn up when clicked. This didn't happen until quite recently.
Could you please advise how best to fix this?
Regards,
I've found this piece of code (I assume it's yours) as you can see there's an error in first line:
'. tri-tabs-nav span'
should be
'.tri-tabs-nav span'
