Immage ration on work page
in FatMoon Posts: 13
Hi! I would like to ask where I can find the immage ratio (WxH) for the immage I select for the work page.
In my case i dıd in photoshop becase my immages where too high and the automatically crop cut too much.... but still it cut a lots.
Regards
    Hello there:-)
    If this is single work then you can find them in each work details, see screen:
    654 x 783 - 41K
    thanks!
    If you are happy with this theme please don't forget to rate us on ThemeForest - it helps us a lot! Thanks! How to rate?
