About Section- Problem
sp3sp3
in FatMoon Posts: 9
1) I'm trying to change the font size of the "TIMOTHY" written across the picture, but when in settings I Change font e.g from 75px to 25px to make it smaller - nothing really happens after I Save changes.
2) Where can I change the size of the picture? Now I see the bottom of it is cut.
Thanks in advance for reply and help!
    Hello
    1) First of all you must uncheck the "responsive font-size" for this custom heading: http://nimb.ws/Az4EbS
    Because this option is helpful on mobile devices. You can of course set your own font size.
    2) Look on this screenshot: http://nimb.ws/qzYlL9 and change the parallax speed to "1" and probably you will be happy ;)
    With Regards
    Lead Graphic Designer
