I've got down to the 'our team' section and there is a post grid which I cant work out. Where is the information stored to change the background images? I'm trying to load in my own but all I can find is the overlay information, nothing about the images underneath.
'Our team' section is displayed by 'post grid' shortocde - that's right.
Data are fetched from posts located in Admin Area >> People.
Please refer to:
http://www.apollo13.eu/docs/fatmoon/#!/adding_people
and
http://www.apollo13.eu/docs/fatmoon/#!/post_grid_shortcodes
How do I change the images under the postgrid?
If you want to change the photo - edit 'Emy Roberts' post in Admin Area >> Left Menu >> People and change the featured image.
I could just edit the people pages to become services but the links would still refer back to the people section. Is that going to cause any other problems elsewhere?
Can I change the people section to services somehow?
As you can see - you can easily adapt People post type and post grid to display something that you call services.
And you've noticed that those have limitations - sure you can modify them.
But instead of modifying things that have specially designed purpose there's another approach.
Just use a flexibility that Visual Composer gives you - look here: http://paris.fatmoon.kinsta.com/services-three-columns/
place an image in the background and voilà.
Presumably there is no problem modifying the post grid for people then? Can I change people to services without significant coding experience?
If you really want to use post grid to show your services - take a look here: http://www.apollo13.eu/docs/fatmoon/#!/post_grid_shortcodes
we prepared several layouts for our purpose, you can choose another layout, and if you can't find any layout that suits your need - you can build your own.
There's a 'Create new' link below list of all Grid Element template. Just click it and play with tools you get there.
I strongly recommend not to modify our Grid Elements (those with 'fatmoon' in name)
With the post grid - hover box, how/where do I edit the layout and size of the text box?
I'd like the text to start higher up the hover box so there is a bit more room for extra words.
Find the right 'Post grid' shortcode on your home page, edit it, navigate to 'Item design' tab, and click 'modify selected' - you're now on your own, if you break it - it will be broken. '160px;' is just an example, adjust it to your needs. original value is 100px.
