Slider Setting of Album
AKIAKI
edited August 2016 in FatMoon Posts: 5
Now I'm making a website using Fatmoon Florence 2 theme.
I set up an album slider to top page like following link.
http://florence2.fatmoon.kinsta.com/album/slideshow3/
However, the problem is the slider is not 100% fullscreen.
There is a space on the right side(See attached pic.)
If I set the album to brick looks fine, there is no space.
It only happened when I choose the album setting as slider (Album media - Present media in: Slider).
How can I fill the image?
Please help!
Thanks,
Post edited by AKI on
    Maybe you have to change option Fit images to other variant. Just pure guess. Live link to your site would help a lot.
  • AKIAKI
    Hi, thanks for the reply.
    I have tried all option, but didn't solve..
    Actually, the website is not open yet.
    Now I tried to re-import demo data, but internal server error happened..
    Do you have any idea..?
    Thanks,
    edited August 2016 Posts: 10,970
    Well reimport won't fix things ;-)
    About import -> http://apollo13.eu/docs/fatmoon/#!/issues_importing_demo_data
    About your main issue: so you have it on localhost for now? I can't debug it until you will place it on some public hosting. Is it possible for you?
  • AKIAKI
    Oh no..I didn't know that..
    About main issue, I mean just in maintenance mode right now,
    so if you can check the website, that'll be great.
    If it's ok, I'll send you login id and pass.
    Thanks,
  • AKIAKI
    hmm... I have no idea why it's different from demo page..
    Could you please send me temporary access to your WordPress and FTP so I could check there what is going on? Send it here on forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please attach LINK to topic it applies to.
    OK I know what is going on, we have spotted this issue, and fix for it will be released in next update. Meanwhile please use this custom CSS(remove it after next theme update):
    html.show-scroll{
    overflow: visible !important;
    html.show-scroll body {
    overflow-y: scroll;
  • AKIAKI
    Thanks for everything!
    The problem was solved.
    Thanks again,
