using visual compser as a editor in frontend
Hi
i m working with many website using fatmoon
but i have a probleme
i cant give my costmer administrator user
i give them editor user
but with editor they cant using visual composer in the frontend , they must login and go in page
have you a advice to me to fixe that
i send you a screnn shot to better explain
i know this not a fatmoon problem so you dont have to answer me but i demand just a advice as a profesionel of wordpress
thanks
    Please see the attached image.
    998 x 878 - 65K
  • thanks but i cant see top admin bar in the frontend when i m using a editor user
  • Hi surgeon i just tested with another website with another template and when i m conected with a editor user i can see the top bar
    so is just a probleme i have with fatmoon
    so if you want a can send you access to see your self
    thanks
    Yes, please send me login credentials via private message, for I cannot confirm your problems.
    OK, so:
    1. editor can use FrontEnd editor, but editor needs to go to pages list, and - while hovering on desired page - click 'Modifier avec Visual Composer'
    2. as for admin bar, which is not displayed - please deactivate all extra plugins you have installed and check then. Still - we will investigate this issue, please stay tuned.
  • Hi
    1- i know i can use when i edit page but i when to make it easy
    2- i dont think its plugin because with my super admin user i can see the top bar but i will desactived all plugin to see
  • yes it was a plugin
    hide my wp
    So we're good?
  • yes very good :)
    That's awesome! I'm glad.
    If there's anything we can do for you - you're welcome.
    There is thou something that you can do for us ;) please rate FatMoon on ThemeForest, that will help us a lot.
  • Just did
