Hi i m using the writing effect but i want the texte continue like a loop i dont want it stop after tree words example words 1,words 2 , words 3 ,words 1,words 2 , words 3 ,words 1,words 2 , words 3 , once it ends its start again
Hello, You are the first person asking for this. Unfortunately at this point there's no such option, but we will consider to incorporate this functionality into FatMoon feature updates.
I have the oposite problem now.
By mistake I changed to a loop but cannot bring it back to stop after the last word
but should be like: http://florence.fatmoon.kinsta.com/about-me-2/
You saved my day! Tanks a lot for ths quick and perfect answer. and: your fatmoon theme is just great! I love it!
