Hello I'd like to increase size and look of the search & menu icon as well as for the "back to top" icon. Where and how can I do so? Thanks for your reply, Pascal
Hello and Thanks for your reply I'd like to change both – sieze and color. For to-top button I'll wait (how long?) for your settings If you could help me out with a css code for menu and search icon that be great. As I will change color and size while working on the site you can choose any color and size.. let's say increase size by 150% and use the color Green (assuming that color and size are part of the css code) Thanks, Pascal
You can do all changes in CSS.
What exactly you wish to change? Color, size?
For to-top button we will add settings pretty soon.
For search and menu - I need to know what you need.
Thanks, Pascal
So colors of icons you can change already in Customizing ▸ Header settings ▸ Tools icons
For their size use this custom CSS: To top button - hopefully we will release update in 2 days.
And could color be changed sepcifically for pages?
Pascal
Update should be available today on TF, if Envato staff won't interfere. Well I don't wish for it:-)
So color or size? And for what element? You will have to target css selectors with your page id, something like this: With kind regards.
