make a same thinks as team
hi
i want make the same caroussel as team ( screenshoot )
but i want when i clic its fo to a costum link
i try to edit team but i dont how set a link to this image
so how to make the same think with the same animation but when i clic on will be open a costum link
    Hello
    You can use the image carousel: http://nimb.ws/26ivyE
    I marked on the screenshot that you need to add a custom links for each image.
    With Regards
    Lead Graphic Designer
  • But with image carousel i cant add some costume text
    Hello
    after some research I must say that - unfortunately - it's not possible with our theme out of box.
    It can be done, but it requires several hours of custom work.
  • Thanks
