I currently have all my client work in separate albums, and an overview of them can be found on the Album List Page, sortable by their relevant tags. However, I would also like to add a separate Album List Page of just my personal work, without any of the client work or their tags showing. What is the best way to achieve this? Is there a way to make a different second Album List Page?
Thank you,
Roy
We have covered this many times and I tried to describe this in docs http://apollo13.eu/docs/photon/#!/adding_multiple_albums_list_and_categories
However if you already use tags/categories I would do such thing:
1. Create two main categories in album: Personal and Clients
2. All your current categories I would push under Clients category and like so for your Personal stuff.
3. Now I would add to menu links to this main categories.
This way you have two separate albums lists.
I hope this helps.
Thanks for your response. One follow-up question -- I have some custom CSS that I've used on my main album list page under Pages (so it does not make global changes to the website), and I would like to carry these over to the other album list page (essentially the "Category" view/genre filter). Is there a particular place where I can put this code to affect only the Category/genre view?
Thanks again!
It depends what exact CSS you have, but we should be able to easily target album genre with selector
body.albums-list-pageWith kind regards.
Thank you.
