WPML Media conflict
CFPCFP
edited October 2016 in Photon Posts: 122
Hi Air, I don't know if it is with photon or with WPML Media.
A conflict between the two appears. In the albums the pictures in the main language are double. Half of them will show up right (thumb) the other half is marked as probably deleted. But if you delete those who are marked probably "deleted", every image is gone.
If the WPML Media Ad-on is disabled it works normally. Your theme did work with that add-on but since a update (yours or WPML Media) it doesn't.
It is only on the backend not on the fronted.
I will also tell this to WPML so that they also can check on this.
Post edited by CFP on
    Hi there:-)
    Thanks for info, I will take a look at it and investigate later.
