I’m trying to understand how a child theme works, but I’m failing…
I made changes to all kind of PHP files like "comments.php", where I just deleted line 480:
<?php _fe( 'Comments are closed.' ); ?>
But how do I integrate a file like "comments.php" in a child theme? Just copying it in the child theme folder where "screenshot.png", "style.css" and "functions.php" are, doesn’t do the trick.
And what about files like "jackbox-packed.min.js" that are in subfolders (in this case: wp-content/themes/beach_apollo/js/jackbox/js)? How do I integrate such edited files into the child theme? I read the documentary over and over but I just don’t find a clue on how to do this…
Thanks a lot.
However two things:
1. I have wrote instructions how to change JavaScript files in child theme for our different theme, so you can use it and try yourself to implement it http://apollo13.eu/docs/apollo13_framework_theme/#!/modification_of_theme_overwriting_javascript
2. You can probably leave all your change in main theme, as Beach Please theme probably won't receive any important updates. I think in some time we will change its status to unsupported on ThemeForest, like we did for some of our legacy themes already.
More detailed explanation is written by me in different docs http://apollo13.eu/docs/apollo13_framework_theme/#!/modification_of_theme_changing_theme_functions
So you don't copy whole files, but only functions that you have changed. In some cases if you modify to deep, there is no more sense in making child theme, as update will be hell anyway if you wish to have new features.
But whatever: If Beach Please will be unsupported soon, it doesn’t really matter. Those few files can be updated easily in less than a minutes. So it’s all fine.
Thank you very much!
Just in case you have the time or feel the urge to explain it – hehe –, here’s what I want to add in functions.php from advance/meta.php (as an example):
advance/meta.php line ~27. Original:
array(
'name' => '',
'type' => 'fieldset',
shall become:
array(
'name' => '',
array(
'name' => __be( 'Subtitle' ),
'desc' => '',
'id' => 'subtitle',
'default' => '',
'type' => 'input'
I don’t get how to integrate this in child theme’s functions.php
See ya around.
