Top filter category won't work across two lines
I need this to work over two lines - how do I do this please?
Can I change the style as it is a little "weak" as well, for example changing to blocks instead of a line and arrow.
Please get back to me asap as once this is done I can launch the site!
Thanks.
You can see the problem here:-
http://www.johncove.co.uk/dev/#a13_Examples
    Yes, you're right, we've never tested it in such situation. Will fix that ASAP and will let you know when it's ready.
  • Ok - I have a web site waiting to go live, so when can I expect this to work?
