I'm using Brooklyn option and I want my logo a little bigger. I uploaded a bigger image but it is resized... Can I use a code so I will increase my logo a little? It is too small right now...
OK, height will not help in this particular situation, so please remove it from settings. Instead try this custom CSS for making your logo wider(it will also make it higher):
go to Customizing >> Header settings >> Logo and use 'Height' number slider to set logos height.
This is the size:
http://www.marianalessa.com.br/wp-content/uploads/2016/11/Captura-de-Tela-2016-11-04-às-10.52.34.png
