Discussions
Categories
Home
FatMoon
edit title on locked work item
vncnt
November 2016
edited November 2016
in
FatMoon
Hi guys,
Is there any place where I can edit the copy "This content is password protected" and "click and enter..." on locked bricks?
see attachment, last bricks on
http://bumsch.com
password is hello
November 2016
vncnt
November 2016
and same question for when you entered the password.
Can I change the title here as well?
see attach.
1402 x 1350
707K
Air
November 2016
Are you sure you use Starter theme?
You should be able to change it in translation file
http://apollo13.eu/docs/apollo13_framework_theme/#!/translating_theme
vncnt
November 2016
Starter theme? How can I tell?
Air
November 2016
You wrote in Starter theme category. Previously you wrote in FatMoon theme category.
November 2016
vncnt
November 2016
O uhh sorry, see what you mean. Yes still working on Fatmoon theme
vncnt
November 2016
Will dive into your offered solution. Cheers!
Air
November 2016
If you won't be able to do it I will dig out code place to edit for you.
vncnt
November 2016
Nice! will keep in mind.
Sign In
or
Register
to comment.
Sign In
Register
Quick Links
Categories
Recent Discussions
Categories
3.7K
All Categories
115
OneLander
325
PhotoProof
591
Rife
40
Agency
130
Starter
886
FatMoon
197
Thirteen
337
Photon
319
Chillout
769
Hypershot
3
General
November 2016
Air
November 2016
vncnt
Discussions
Categories
Sign In
see attach.
You should be able to change it in translation file http://apollo13.eu/docs/apollo13_framework_theme/#!/translating_theme
