Responsive menu
How do I remove or change "undefined":-
    This is a glitch, will remove it ASAP.
    But it will not be visible if you want to have social icons visible.
    Nevertheless - I'll fix that.
    Thank you.
  • Ok - I have a web site waiting to go live, so when can I expect this to work?
    Fixes are done, but those must go through the Envato, and they must accept them, so if you want me to apply them without waiting - please provide as FTP access, send me credentials via private message.
  • Thanks!
    done.
    now go to CeeVee Options>>Custom Style and paste this definition:
    .categories_filter_wrapper {
      margin: 0 10px 60px 0;
  • Thanks for doing it so quickly but it simply doesn't look very good - looks untidy:-
    http://www.johncove.co.uk/dev/#a13_Examples
  • The margins are different for the underlining meaning there is a space plus it looks messy - can you please look at the design here.
    1056 x 199 - 26K
    Yes, this was more like removing glitches, you can expect further improvements tomorrow.
    Try now, and use this additional definition in CeeVee Options>>Custom Style:
    .categories_filter {
    -webkit-box-pack:center;
        -ms-flex-pack:center;
            justify-content:center;
  • I have added this - doesn't seem to have made any difference.
    How can I change the line and arrow to a simple box with selectable background? Would feel a lot better to the user, for example:-
    http://www.ritvawestenius.co.uk/dev/bridalwear
    Well - you can do it with custom css, I'll provide example on Monday.
  • Thanks.
  • edited November 2016 Posts: 1,758
    Please check now. Colors need to be tuned, just play with css in CeeVee options >> Custom Style.
    Post edited by surgeon on
  • Thanks - I will look tomorrow.
  • How do I remove the extra high space below the first line of links so the spacing looks uniform?
    Also, how do I add a background colour so they look more like buttons/boxes that have more impact and imply they should be pressed.
    Thanks for your help.
    1265 x 279 - 64K
    If you can't modify styles on your own - please provide me a detailed information (graphic design) of how you want it to look like. I'll perform these modifications for you in my spare time.
  • I can't change the margin / padding as requested, no. It looks like they are being dynamically created.
    If you can add the required styling, I can then update it to the colours I need and spacing I need. I am sorry to be a pain.
    I just need the margins looking uniform (at the moment they look un-tidy) and the background for each button changing to the same colour as the borders which then change on hover.
    But you can change styles in CeeVee Options >> Custom Style panel.
    I changed the margin, check now. Please - you can change it by yourself.
  • Thank you. I understand your position here and know you've helped me lots already - thank you!
  • I noticed this is not responsive and has caused some problems on my mobile - see attached screen shot. Can you please help with this as the web site will be viewed by people on mobiles / smart phones / tablets mostly as we all know.
    http://www.responsinator.com/?url=www.johncove.co.uk
    You will see the nav filter text per section sits behind the pictures.
    Thanks.
  • This is outstanding and i have been very patient. Can you get back to me please.
    Hi, sorry
    I overseen this reply among your other topics.
    johncove said: You will see the nav filter text per section sits behind the pictures.
    I checked that, you are talking about the navigation buttons not being animated while section are closed, right?
    If so - I'll check it.
    If not - please provide more detailed description
    If you are asking for element marked on screenshot - then it's not a bug, this was designed like this,
    413 x 900 - 38K
  • No, this is not the area I am talking about
  • Please go to this link:-
    Then navigate to MY WORK
    Then you will see the problem - the filtering buttons are appearing behind the content therefore the user cannot click to filter the content
    Maybe I should go back to how it was before? Either way, this is a poor solution for mobile users.
    See the problem?
    got it!
    will fix this today. please stay tuned.
    Please use this css definition:
      display: table;
      border: medium none !important;
    .categories_filter li {
    display: inline-table!important;
      border: 1px solid;
      margin-left: 5px !important;
      margin-right: 5px !important;
  • Thank you :)
