Add "Go back to shop" button on single product page
in FatMoon Posts: 304
Hello
When I click on a product on my shop page I miss a "back to shop" button. Is there an easy way to add this to my single products.
Thanks, Pascal
    Hello there:-)
    You can try solution from woocommerce support https://wordpress.org/support/topic/add-continue-shopping-button-to-product-pages/
  • edited November 2016 Posts: 304
    Hi
    Thanks for the Link.. I actually found something even better (I wanted a button :)) and I'm almost happy now... the only problem I have is placing the button in the right place!
    I used this code
    //add back to store button after cart
    add_action('woocommerce_single_product_summary', 'themeprefix_back_to_store');
    function themeprefix_back_to_store() { ?>
    <a class="button wc-backward" href="<?php echo get_permalink( wc_get_page_id( 'shop' ) ); ?>"><?php _e( 'Return to Store', 'woocommerce' ) ?></a>
    <?php
    Maybe putting it where I want is an easy thing for you? (see screenshot)
    Using a textlink for that puts it in the right place:
    add_action( 'woocommerce_single_product_summary', create_function( '', 'echo "<a href=\"YOUR_SHOP_PAGE_URL\">Continue Shopping</a>";' ), 35 );
    Thank you
    Pascal
    1435 x 1114 - 253K
    Sorry for late reply, I must have missed your answer :-S
    Change this code from your original code
    to
    add_action('woocommerce_single_product_summary', 'themeprefix_back_to_store', 35);
    It should work ;-)
    Hi there
    Thanks.. that worked like a charm :))
