Getting shown code instead of content on the Works Lists page
Basically when I try adding any type of content other than the works list, I am getting shown code but not the content I want showing.
    Are you using any extra plugins? If so - please deactivate them all, and check then.
    If not - please provide the url of your website. I'm pretty sure that I'd need login credentials as well to investigate what's wrong. Send them via private message.
  • I disabled all plugins but the ones for theme, also tried disabling them all, still no change.
    Hi there:-)
    Could you post link to your site? Maybe we will find source of this issue there.
