When I install a template that requires the installation of plug-ins. I encounter an error with the plugin Revolution Slider.
Reports an error:
Plug asked 2,972 unexpected characters when turning. If a screen your site gets subtitle "headers already sent", problems with new channels or other problems, try to disable or remove this plug.
Detailed information in the screenshot.
I can not solve it alone. Please help.
Regards
PS: Sorry for my English.
Maybe someone will need to:
1. Open "base-admin.class" directory: \wp-content\plugins\revslider\includes\framework
2. Edit line 430:
$options = array_merge($options_exist, $options);add (array):
$options = array_merge((array)$options_exist, (array)$options);glad you found a solution! You Master!
